- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
D7000 UK firmware updated to V1.0.1.42_1.0.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just applied the update tonight and now when I log into the router, on the home page it shows wireless as "warning - No security". I have WPA2 configured on 2.4 and 5G, is this a bug?
Something odd happening here? My Win10 PC is of course showing the connections as being secured.
Thanks
Mark
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D7000 UK firmware updated to V1.0.1.42_1.0.1
I had the same issue as you but after setting up my Guest network using WPA2-PSK [AES] it seems to make the Warning message disappear
- Mark as New
- Bookmark
- Subscribe
- Permalink
i dont even have guest network on but still getting it....I got a readynas102. which is now shutting down without any error as well. WTF
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello everyone
I would suggest backing up your config and factory resetting the modem sometimes when updating firmware without a reset can cause strange issues.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you read my separate thread you will see that I did try doing exactly what you suggest. This made absolutely no difference and it was only after reinstalling the previous version of firmware (38) that the issues were resolved.
