- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear D1500
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear D1500
You are not connected to your Router’s WiFi network. To access routerlogin.net, your device must be connected to your Router’s WiFi network. Check your current connection and try again.
I forgot the router login password and so i factory reset my router n after doing this i stuck to this problem....
i m getting connected to router..
but it seems that router is not getting connected to network....
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear D1500
Not sure that I follow what is going on here.
The password for the router login and for the wifi are not the same. (Unless you changed them to be the same.) Nor are these the same passwords as the one your ISP uses for you to login to the internet.
Can you connect to the wifi?
Is the modem connected to the internet?
What device are you trying to login from? (PC, laptop, phone, tablet?)
Are you using a browser or the standalone Netgear genie?
Go gere for the manual and more:
D1500 | Product | Support | NETGEAR
