- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
D7800
- Mark as New
- Bookmark
- Subscribe
- Permalink
D7800
We purchased a D7800-AC266 WifiVDSL/ADSL Modem Router in June 2021. We have been notified by our internet supplier that before the end of this month (March 2022), we need our modem to be SOS/ROC compatible. I only found very little information about it.
Is our modem SOS/ROC compatible?
If not, will any software/firmware update make it SOS ROC compatible?
If so, could you tell me what version please?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D7800
I don't believe the D7800 has sos/roc.
the only ones i know of that do is D7000v1, D6220, D6400
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D7800
You might like to follow this discussion:
Re: SOS and ROC Updates - NETGEAR Communities
Your ISP has changed the way it delivers the Internet to you since you bought your modem/router.
As this was its idea, the ISP should be prepared to provide a modem that works with the new system. You can then use your existing D7800 as a router behind this new modem. This should a relatively easy switch.
Many of us think that having a separate modem and router is a good idea. You have a much wider choice of router features if you ever decide to upgrade your hardware.
