Orbi WiFi 7 RBE973
Reply
D8500 restart, and wifi problem
kmotala
Hello!!!
I have problem with my d8500. Router has sometimes problem with wifi. My laptop and smartphone can't connect to wifi, after restart wifi connection work. Sometime router has unexcepted  restart.  I use last firmware
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 5
DarrenM
Sr. NETGEAR Moderator
Re: D8500 restart, and wifi problem
Hello Kmotala
Have you tired to change the wireless channel?
DarrenM
Message 2 of 5
kmotala
yes, but not help.
Message 3 of 5
DarrenM
Hello Kbotala
Have you tried to remove the network from the device and then reconnect to it.
DarrenM
Message 4 of 5
kmotala
 Yes , I try everything.  This is beta sample mayby final release don't have this problem.
Message 5 of 5
Discussion stats
  • 4 replies
  • 3427 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
