Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DGN2200v4 very slow connection speed wired and wireless.
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-11-02
12:37 PM
2016-11-02
12:37 PM
Hi all.
When i look at my connection status on my router using the show statistics my downstream speed and upstream speed is 700kbps which is correct. However when i do a speed test with speedtest.net it never goes more than 50kbps wired and wireless.
Did i change a setting without knowing it. It should be 700kbps download. Any advice?
Regards
Regards
Message 1 of 2
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-11-09
03:43 PM
2016-11-09
03:43 PM
Re: DGN2200v4 very slow connection speed wired and wireless.
Hello Anza
I would try changing your Ethernet cable make sure that is not the issue and change the wireless channel. Also when using speedtest check multiple locations to see if you get similar results.
DarrenM
Message 2 of 2
Announcements
