Orbi WiFi 7 RBE973
Reply
Fibre Modem+Router
Nsesha
Follower
Fibre Modem+Router
Hi,
I am looking for a Fibre Modem + Router with WiFi for connection to BSNL's FTTH:
http://www.bsnl.co.in/opencms/bsnl/BSNL/services/broadband/ftth_overview.html
In the above diag, HONT is the box that I am wanting to buy.
Input:
1. Fibre input cable connection for Internet + Voice usage
Outputs:
2. One or 2 copper wire telephone outputs (RJ11) to connect normal phone. (not IP telephone).
3. or 4 ethernet LAN RJ45 ports
4. WiFi connectivity
Of the above, 1, 3 and 4 are must, 2 is preferable, but if not available, its ok.
Do you have such a product and if so what is the product no ?
Thanks
Seshadri
Message 1 of 2
clithes
Prodigy
Re: Fibre Modem+Router
From the details on the link the Home Optical Network Termination looks bespoke, and probably manufactured specifically for BSNL by a third-party.  The website states that BSNL will provide this to the customer.
Why would you want to purchase one if it is going to be supplied ?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2365 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
