- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How do I set up VOIP on my D6200?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I have the VOIP settings from my ISP but am not sure where/how to enter them on the router? Can you please let me know how to configure?
thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How do I set up VOIP on my D6200?
Hello jobloggs
What are the voip settings that you need to add?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Darren - I believe these are the settings I need to enter...
SIP domain: iinetphone.iinet.net.au
SIP server: sip.vic.iinet.net.au
Username: Your Netphone number (no spaces or brackets)
Password: Your Netphone password
Re-registration time interval: 300 seconds
Codec preference: G.711 A-Law and/or U-Law (if available) otherwise G.729
DNS: Use SRV records
Display name: iinetphone
Proxy IP: sip.vic.iinet.net.au
Registrar IP: sip.vic.iinet.net.au
- Mark as New
- Bookmark
- Subscribe
- Permalink
By the look of the manual the D6200 is not a VoIP router.
Consequently there is nowhere to enter these settings and there are no phone ports on the router (other than the DSL port) so you can't connect a handset either.
If you want to use the iiNet VoIP service with the D6200 and not use the iiNet modem you probably have with your service you will need to add a device that can provide the service.
An ATA, like the Cisco SPA 112, is one fairly low cost option.
Ian
