- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New firmware with built in Torrent Client
- Mark as New
- Bookmark
- Subscribe
- Permalink
Rif.: New firmware with built in Torrent Client
Great release... just a bit sad for the mispelling of my name 😭
- Mark as New
- Bookmark
- Subscribe
- Permalink
How odd! This doesn't authenticate to the ISP. The line trains, DSL LED goes solid green and UI shows up and down link speeds. Internet LED stays solid red. It never logs in to the ISP and gets an IP address. Went back to prior version and it logs in fine. Verified UID and password and they're correct, but no Internet. What should I look at?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It occurred to me to grab the log, here is the way it ended up. The last line just continues to repeat...
May 15 00:00:29 DGND3800B user.warn kernel: Broadcom Packet CMF (Experimental) SAR INITIALIZED. |
May 15 00:00:29 DGND3800B user.warn kernel: bcmxtmcfg: Connection UP, LinkActiveStatus=0x1, US=892000, DS=15871000 |
May 15 00:00:34 DGND3800B daemon.err dhcpc[1872]: started, v1.26.2 |
May 15 00:00:34 DGND3800B user.emerg kernel: abNatUnhook(1595) <Warning> not find atm0.8 in nat hooked interface list |
May 15 00:00:34 DGND3800B daemon.err dhcpc[1872]: sending discover |
May 15 00:00:37 DGND3800B daemon.err dhcpc[1872]: sending discover |
May 15 00:00:40 DGND3800B daemon.err dhcpc[1872]: sending discover |
- Mark as New
- Bookmark
- Subscribe
- Permalink
w3: hmmmmm, there aren't many changes in firmware and nothing that should cause a problem with dhcp getting a lease - what is the specific firmware version that works and what version of Busybox is it using? Thnkx.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here's what works...
The firmware version -
Firmware Version : 2017-03-17_3.1.22
BusyBox -
BusyBox v1.25.1
This is the first time I've ever had this problem.
It doesn't look like it's signing in which I'd guess has to happen before DHCP would offer up an IP?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is in the log of it working after 'Connection UP' please? (can email them to w3 AT richud.com if easier)
Comparing the codebase the only two relevant things changed are some code mods to dhcpc in busybox (most likely) and some mods for Luke with pppd (pppoe part) but they should only happen if setting the 'pppoe extras' entries.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sent email to w3 AT richud.com
- Mark as New
- Bookmark
- Subscribe
- Permalink
i also got sending discover log on my dgnd3700 v1, what i did is disabled wan 2 and it stop
- Mark as New
- Bookmark
- Subscribe
- Permalink
The 2 lines before DHCPC and the 8 lines after DHCPC started don't happen on the new firmware and the DHCPC starts on both, but DHCPC is an older version on the 17 March firmware. My connection is just ADSL shown below.
Mar 16 20:00:29 DGND3800B user.warn kernel: wl1: received packet with own address as source address |
Mar 16 20:00:29 DGND3800B user.crit kernel: Line 0: ADSL link up, Bearer 0, us=892, ds=15871 |
Mar 16 20:00:29 DGND3800B user.warn kernel: bcmxtmcfg: XTM Link Information, portid = 0, State = UP, Service Support = ATM |
Mar 16 20:00:29 DGND3800B user.warn kernel: bcmxtmcfg: Reinitialize port 0 traffictype 1 |
Mar 16 20:00:29 DGND3800B user.warn kernel: bcmxtmcfg: Normal(XTM/PTM) Mode enabled |
Mar 16 20:00:29 DGND3800B user.warn kernel: Broadcom Packet CMF (Experimental) SAR RESET. |
Mar 16 20:00:29 DGND3800B user.warn kernel: Broadcom Packet CMF (Experimental) SAR INITIALIZED. |
Mar 16 20:00:29 DGND3800B user.warn kernel: bcmxtmcfg: Connection UP, LinkActiveStatus=0x1, US=892000, DS=15871000 |
Mar 16 20:00:33 DGND3800B daemon.notice pppd[1864]: pppd 2.4.1 started by root, uid 0 |
Mar 16 20:00:33 DGND3800B daemon.notice pppd[1864]: PPP: Start to connect ... |
Mar 16 20:00:35 DGND3800B daemon.err dhcpc[1871]: started, v1.25.1 |
Mar 16 20:00:35 DGND3800B user.emerg kernel: abNatUnhook(1595) <Warning> not find atm0.8 in nat hooked interface list |
Mar 16 20:00:35 DGND3800B daemon.err dhcpc[1871]: sending discover |
Mar 16 20:00:36 DGND3800B daemon.crit pppd[1864]: PPP server detected. |
Mar 16 20:00:36 DGND3800B daemon.crit pppd[1864]: PPP session established. |
Mar 16 20:00:36 DGND3800B daemon.crit pppd[1864]: PPP LCP UP. |
Mar 16 20:00:36 DGND3800B daemon.crit pppd[1864]: Received valid IP address from server. Connection UP. |
Mar 16 20:00:38 DGND3800B daemon.err dhcpc[1871]: sending discover |
Mar 16 20:00:39 DGND3800B user.notice wan-up.sh: WAN up event Start |
Mar 16 20:00:40 DGND3800B user.emerg kernel: abNatUnhook(1595) <Warning> not find ppp0 in nat hooked interface list |
Mar 16 20:00:40 DGND3800B user.emerg kernel: IOCTL_AG_MM_GROUP_SET invoked. |
Mar 16 20:00:41 DGND3800B daemon.err dhcpc[1871]: sending discover |
Mar 17 00:00:49 DGND3800B daemon.info dnsmasq[726]: read /tmp/dnsmasq.hosts - 1 addresses |
Mar 17 00:00:49 DGND3800B daemon.info dnsmasq[726]: using local addresses only for domain lan |
Mar 17 00:00:49 DGND3800B daemon.info dnsmasq[726]: using nameserver 8.8.4.4#53 |
Mar 17 00:00:49 DGND3800B daemon.info dnsmasq[726]: using nameserver 205.171.2.25#53 |
Mar 16 20:00:51 DGND3800B user.notice wan-up.sh: WAN up event End |
May 16 22:03:59 DGND3800B daemon.err dhcpc[1871]: sending discover |
May 16 22:04:02 DGND3800B daemon.err dhcpc[1871]: sending discover |
May 16 22:04:05 DGND3800B daemon.err dhcpc[1871]: sending discover |
May 16 22:04:28 DGND3800B daemon.err dhcpc[1871]: sending discover
Here’s the same log area from the 15 May firmware;
May 15 00:00:29 DGND3800B user.warn kernel: Broadcom Packet CMF (Experimental) SAR INITIALIZED. May 15 00:00:29 DGND3800B user.warn kernel: bcmxtmcfg: Connection UP, LinkActiveStatus=0x1, US=892000, DS=15871000 May 15 00:00:34 DGND3800B daemon.err dhcpc[1872]: started, v1.26.2 May 15 00:00:34 DGND3800B user.emerg kernel: abNatUnhook(1595) <Warning> not find atm0.8 in nat hooked interface list May 15 00:00:34 DGND3800B daemon.err dhcpc[1872]: sending discover May 15 00:00:37 DGND3800B daemon.err dhcpc[1872]: sending discover May 15 00:00:40 DGND3800B daemon.err dhcpc[1872]: sending discover |
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New firmware with built in Torrent Client
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello richud,
Would be possible to add fail2ban or sshguard features to firmware?
Thanks in advance
Best Regards,
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Uploaded latest, 2017-05-15, richud firmware but my router does not want to connect to internet it was the same with the previous version as well. After installing richud I couldn't and can't go online. I am a Sky user in UK. What am I doing wrong? Do I need to input some connection data to it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Luke, Yes - WAN2 was enabled. I've now disabled WAN2. Made no difference other than getting rid of all those DHCPC discover messages.
@rich,
Reloaded the 15 May firmware with WAN2 disabled. For this log I unplugged the DSL line and plugged it back in. It shows from the ADSL link down to as far as it goes.
May 15 00:13:43 (none) user.crit kernel: Line 0: ADSL link down
May 15 00:13:43 (none) user.warn kernel: bcmxtmcfg: XTM Link Information, portid = 0, State = DOWN, Service Support = ATM
May 15 00:13:43 (none) user.warn kernel: Broadcom Packet CMF (Experimental) SWC FLUSHED.
May 15 00:13:43 (none) user.warn kernel: bcmxtmcfg: Reinitialize port 0 traffictype 1
May 15 00:13:43 (none) user.warn kernel: bcmxtmcfg: Normal(XTM/PTM) Mode enabled
May 15 00:13:43 (none) user.warn kernel: bcmxtmcfg: Connection DOWN, LinkActiveStatus=0x0
May 15 00:13:45 (none) user.crit kernel: Line 0: xDSL G.994 training
May 15 00:13:56 (none) user.crit kernel: Line 0: ADSL G.992 started
May 15 00:14:01 (none) user.crit kernel: Line 0: ADSL G.992 channel analysis
May 15 00:14:07 (none) user.crit kernel: Line 0: ADSL G.992 message exchange
May 15 00:14:08 (none) user.crit kernel: Line 0: ADSL link up, Bearer 0, us=892, ds=15871
May 15 00:14:08 (none) user.warn kernel: bcmxtmcfg: XTM Link Information, portid = 0, State = UP, Service Support = ATM
May 15 00:14:08 (none) user.warn kernel: bcmxtmcfg: Reinitialize port 0 traffictype 1
May 15 00:14:08 (none) user.warn kernel: bcmxtmcfg: Normal(XTM/PTM) Mode enabled
May 15 00:14:08 (none) user.warn kernel: Broadcom Packet CMF (Experimental) SAR RESET.
May 15 00:14:08 (none) user.warn kernel: Broadcom Packet CMF (Experimental) SAR INITIALIZED.
May 15 00:14:08 (none) user.warn kernel: bcmxtmcfg: Connection UP, LinkActiveStatus=0x1, US=892000, DS=15871000
Here's the same piece of log using the 17 March firmware. The starting of pppd that happens in the 17 March does not happen in the 15 May firmware. I don't know how that gets triggered. Is it something I could try to start manually by logging in to the router from Putty? If so, how?
May 17 08:40:24 DGND3800B user.crit kernel: Line 0: ADSL link down
May 17 08:40:24 DGND3800B user.warn kernel: bcmxtmcfg: XTM Link Information, portid = 0, State = DOWN, Service Support = ATM
May 17 08:40:24 DGND3800B user.warn kernel: Broadcom Packet CMF (Experimental) SWC FLUSHED.
May 17 08:40:24 DGND3800B user.warn kernel: bcmxtmcfg: Reinitialize port 0 traffictype 1
May 17 08:40:24 DGND3800B user.warn kernel: bcmxtmcfg: Normal(XTM/PTM) Mode enabled
May 17 08:40:24 DGND3800B user.warn kernel: bcmxtmcfg: Connection DOWN, LinkActiveStatus=0x0
May 17 08:40:25 DGND3800B daemon.crit pppd[1851]: Clear IP addresses. Connection DOWN.
May 17 08:40:25 DGND3800B daemon.crit pppd[1851]: Clear IP addresses. PPP connection DOWN.
May 17 08:40:26 DGND3800B daemon.err ipsec_setup: ...Openswan IPsec stopped
May 17 08:40:26 DGND3800B daemon.err ipsec_setup: Stopping Openswan IPsec...
May 17 08:40:26 DGND3800B daemon.err ipsec_setup: stop ordered, but IPsec does not appear to be running!
May 17 08:40:26 DGND3800B daemon.err ipsec_setup: doing cleanup anyway...
May 17 08:40:35 DGND3800B daemon.info pppd[1851]: Exit.
May 17 08:40:38 DGND3800B user.crit kernel: Line 0: xDSL G.994 training
May 17 08:40:49 DGND3800B user.crit kernel: Line 0: ADSL G.992 started
May 17 08:40:54 DGND3800B user.crit kernel: Line 0: ADSL G.992 channel analysis
May 17 08:41:00 DGND3800B user.crit kernel: Line 0: ADSL G.992 message exchange
May 17 08:41:01 DGND3800B user.crit kernel: Line 0: ADSL link up, Bearer 0, us=892, ds=15871
May 17 08:41:01 DGND3800B user.warn kernel: bcmxtmcfg: XTM Link Information, portid = 0, State = UP, Service Support = ATM
May 17 08:41:01 DGND3800B user.warn kernel: bcmxtmcfg: Reinitialize port 0 traffictype 1
May 17 08:41:01 DGND3800B user.warn kernel: bcmxtmcfg: Normal(XTM/PTM) Mode enabled
May 17 08:41:01 DGND3800B user.warn kernel: Broadcom Packet CMF (Experimental) SAR RESET.
May 17 08:41:01 DGND3800B user.warn kernel: Broadcom Packet CMF (Experimental) SAR INITIALIZED.
May 17 08:41:01 DGND3800B user.warn kernel: bcmxtmcfg: Connection UP, LinkActiveStatus=0x1, US=892000, DS=15871000
May 17 08:41:05 DGND3800B daemon.notice pppd[2029]: pppd 2.4.1 started by root, uid 0
May 17 08:41:05 DGND3800B daemon.notice pppd[2029]: PPP: Start to connect ...
May 17 08:41:07 DGND3800B daemon.crit pppd[2029]: PPP server detected.
May 17 08:41:07 DGND3800B daemon.crit pppd[2029]: PPP session established.
May 17 08:41:07 DGND3800B daemon.crit pppd[2029]: PPP LCP UP.
May 17 08:41:07 DGND3800B daemon.crit pppd[2029]: Received valid IP address from server. Connection UP.
May 17 08:41:09 DGND3800B user.notice wan-up.sh: WAN up event Start
May 17 08:41:12 DGND3800B user.emerg kernel: abNatUnhook(1595) <Warning> not find ppp0 in nat hooked interface list
May 17 08:41:12 DGND3800B user.emerg kernel: IOCTL_AG_MM_GROUP_SET invoked.
May 17 06:41:19 DGND3800B daemon.info dnsmasq[709]: read /tmp/dnsmasq.hosts - 1 addresses
May 17 06:41:19 DGND3800B daemon.info dnsmasq[709]: using local addresses only for domain lan
May 17 06:41:19 DGND3800B daemon.info dnsmasq[709]: using nameserver 8.8.4.4#53
May 17 06:41:19 DGND3800B daemon.info dnsmasq[709]: using nameserver 205.171.2.25#53
May 17 08:41:21 DGND3800B user.notice wan-up.sh: WAN up event End
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Chaps
Appologies, appears there is a problem with the pppd changes, have removed download link on wiki.
w3: I think you originally had WAN2 enabled and although will result in lots of needless dhcp requests on wan2 it wont cause a problem. Now that is all you are seeing though, as pppd isnt coming up from WAN1.
I presume everyone with a problem is using PPPoE connections?
I will do a rebuild without the pppd changes and then ask that you can try that and at least confirm that is the cause, then try and figure out what is the problem. Sorry!
- Mark as New
- Bookmark
- Subscribe
- Permalink
1) connection type (pppoe, pppoa etc)
2) have you got wan2 enabled, if so, disable wan2
3) have you got a vlan ID set/enabled on wan1 unnecessarily?
cheers
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Richud,
1) PPPoE
2) WAN2 disabled
3) vlan ID unchecked
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is build without the new pppd patches, so hopefully will work ok for everyone (except Luke!)
https://mega.nz/#!FA53DAQL!2YHDJeqoaIZvZxf4IJ-k3EU9OKTwQZo4CSj_73tsG2Q
@yonesmit : they both rely on ipchains (well fail2ban definately does as use it on mail server! - it looks like other does too) and this firmware uses netgears proprietary acos stuff I am afraid.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@richud is there any way to ban and unban an ip? maybe using your nat.c to call any agApi_fw.... function in libnat.so
If we can ban/unban then developing the parsing of messages log and calling ban/unban can be done.
Thanks in advance
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks again for another great release, really appriciated.
I am a bit confused with the last update. My DGND3700 shows too much disk space.
2G vs 128M
Am I missing something?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, richud! It's great firmware, great thanks, but i have two questions. How can I change the timezone, where? And is it possible to upload a file manager for files not bt?
- Mark as New
- Bookmark
- Subscribe
- Permalink
