Orbi WiFi 7 RBE973
Reply
No matter what, ma NAT stays closed.
Simon91
Hi everyone.
I have a NETGEAR router, and everything was fine until yesterday.
My ps4 suddenly said that there could be problems with chatting, and after an analysis, i found that i have a type 3 nat (closed).
First of all, i already knew when i installed my modem/router that i would have needed an open nat to play efficently, so i set everything to match at least thee type 2 NAT (moderate).
Everything was damn fine.
Now, that this happened, it doesnt matter which setting i edit. Nothing happens, it stays on 3 no matter that i set NAT open, disabled port scanning, disable SIP, upnp on or off... always closed NAT.
My network is nothing strange (dls cable -> modem/router -> ethernet -> ps4)
Can you help me please? i'm going nuts.
Model: DGN2200Bv4|N300 Wireless ADSL2+ Modem Router
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: No matter what, ma NAT stays closed.
Hello Simon91
Here is a article about opening nat on consoles
http://kb.netgear.com/app/answers/detail/a_id/19844?cid=wmt_netgear_organic
DarrenM
Message 2 of 3
Simon91
thank you for the answer, but my setup is not like the one described in the guide.
I just have a modem router (your Netgear DGN2200v4) that is simply connected to a dsl cable, and with PPPoE protocol is giving me internet.
Everything is attached directly to it (included the console, cabled).
It just won't open the ports. UPnP on/off, disabling nat filtering, port forwarding, dmz, i've tried everything.
What could it be?
Thanks...
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2828 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
