- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Regarding availability of IP address reservation
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does D500 supports IP address reservation? I have a printer for which I want to assign a static IP, settings on printer are done and setup works too. but sometimes when printer is off and if I connect a mobile phone, then it gets assigned same IP as printer. I want to bind that IP to printer's mac address, but unable to find such settings in router configuration.
P.S. I'm already on latest firmware V1.0.0.28_1.0.1PE
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] if I set DHCP range to say for eg., 192.168.x.11-192.168.x.255
> and setup printer on static IP betweent 192.168.x.2-10, would that work?
If the D500 has the required features, then sure. (And that would
then be a true static address, not a reserved dynamic address.)
I might choose a DHCP pool range like, say, ".100" - ".254", to make
it more obvious which devices have static/dynamic addresses.
The critical thing is to keep static addresses out of the DHCP pool.
Around here, with a feature-rich D7000, I have static addresses on all
my old junk, and reserved addresses for almost everything else, so I
have a DHCP pool which is unusually small (16 wide). And just in case
the DHCP server is stupid, my reserved addresses are also outside the
pool.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Regarding availability of IP address reservation
> Does D500 supports IP address reservation? [...]
I don't see it (or much else) in the D500 User Manual. "Essentials
Edition" appears to be a polite way to say "barely a router".
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. Guess I should've done better research before buying. dlink atleast doesn't strips off basic functions.
on the other thought if I set DHCP range to say for eg., 192.168.x.11-192.168.x.255 and setup printer on static IP betweent 192.168.x.2-10, would that work?
- Mark as New
- Bookmark
- Subscribe
- Permalink
pool.
- Mark as New
- Bookmark
- Subscribe
- Permalink
pool.
It Worked!, Had settings under Advanced--> LAN Setup
