Orbi WiFi 7 RBE973
Reply
Setup issue
Jasonolga
Setup issue
When I try a first setup the dsl with filter is connected and the router boots up it won’t connect to the internet the symbol is solid amber and the sync twisted cable symbol is flashing green I use the app to troubleshoot and it says no dsl cable is connected but it is I’ve tried resetting the router with no luck any advice in layman’s terms please as I’m not that tech savvy I’m with SSE broadband
Model: DGND4000|N750 Wireless Dual Band Gigabit ADSL2+ Modem Router
Message 1 of 4
Accepted Solutions
Re: Setup issue
The DGND4000 listed in your footer is an old (2012/13) DSL modem router.
Netgear's manual says ADSL2+. That's old technology. Newer DSL is VDSL. Do you know that this thing is compatible with your Internet service?
SSE is a UK thing. Last time I looked, ADSL was dead here. BT, which hosts most third party Internet services, abandoned ADSL a while back.
Just another user with a set of boilerplate macros.
My network DM200 -> MK93; R7800 -> GS316 -> PL1000 -> R7000P
Message 3 of 4
All Replies
w3wilkes
Prodigy
Re: Setup issue
The filter goes on any phones that you have. Do not put the filter on the connection to the modem/router.
̶D̶7̶0̶0̶0̶v̶2̶ POS / DGND3700v1
Message 2 of 4
Re: Setup issue
Message 3 of 4
Jasonolga
Re: Setup issue
Thanks for the info 👍
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 797 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
