- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
d6400 wireless problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
hi there,
im having a very annoying wireless issue with this new d6400,for some reason it wont supply more than 40 megs wirelessly on 5g ac.
range is fine though. its doing this with any wireless clients i connect to,latest ios or android ac devices. i factory resseted it twice without success. im on bt infinity 2.
i love the stable modem though and the nice sync and ping. its a shame im having to use it in modem modem mode only and using my asus rt-n66u and everything is back to normal wirelessly with downloading speeds exceeding 70 megs.
i have left everything in default mode choosing europe.
can someone who is getting more than 70 megs wirelessly please share their wireless configuration settings.
thanks,
kannanni
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: d6400 wireless problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is it only low throughput with WiFi only or it's also low in LAN ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
zeuss wrote: Is it with VDSL or ADSL mode ? Which ISP ?
vdsl with bt infinity 2 in uk.
happens only on wifi internet bandwith supplied by the router doesnt exceed 40 megs to any of my clients. normal local transfers are not affected speed wise.
no one so far has come forward using the same router to admit internet speed through wifi reaching 70-80 megs levels so it looks there is a software issue limiting the internet speed through wifi.
wired lan is not affected at all.
- Mark as New
- Bookmark
- Subscribe
- Permalink
How about try to change to "Australia" region (in wireless setup page), normally, it will have high power in Australia than Europe.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am on BT Infinity but only have 38M service due to my distance from the cabinet so I can't confirm your findings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It would be best to contact NETGEAR support for any recommendations or solutions since you are the first to report such issue.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
