Orbi WiFi 7 RBE973
Reply
internet dropping out on d7000v2
emmmr
Guide
I have just purchased a new Netgear D7000v2.  All set up and works fine with all devices.
Problem is that internet connection drops out and unit has to be rebooted to get it going again.
What can I do to sort this out
Message 1 of 15
Accepted Solutions
emmmr
Guide
Re: internet dropping out on d7000v2
After contacting Netgear for support I was advised to change 2.4 chanel from auto to C6 and 5.0 to a high chanel. This has been done and since then the router has not dropped out.
Message 15 of 15
All Replies
w3wilkes
Prodigy
What version firmware are you running? Most recent and all prior versions can be found here
https://www.netgear.com/support/product/D7000v2.aspx#Firmware%20Version%201.0.0.56
Message 2 of 15
emmmr
Guide
Thanks for response.  On installation the firmware was updated to 'latest' version.  I will dig out the file on it when I get back home and respond again tomorrow.
Message 3 of 15
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
Message 4 of 15
emmmr
Guide
Thanks for your comment.  I will factory reset and see if this stops the loss of internet.
Interestingly, the wifi drops off once every night. Reboot in the morning enables normal service all through the day. While asleep it drops off at some and again reboot in the morning.
Message 5 of 15
Does that mean that it is the wifi that dies and not the Internet?
Message 6 of 15
emmmr
Guide
Good question.  Will be testing for that by leaving a laptop plugged in to router and when all devices via wifi do not work will check laptop to see if internet is working via cable.  Will advise outcome.
Message 7 of 15
The LEDs will indicate what is going on. Compare the internet LED and the wifi LED.
Message 8 of 15
emmmr
Guide
Will check and make a note next time I loose connection.
Message 9 of 15
emmmr
Guide
The firmware update when router first switched on was updated to : 1.0.0.56_1.0.1
The router was not rebooted after firmware completed.
Message 10 of 15
emmmr
Guide
Should have said that a factory reset was not done after firmware update
Message 11 of 15
The device reboots itself as a part of the firmware update.
Message 12 of 15
emmmr
Guide
Latest update :
Router has been fine over a couple of days, no drop out.
This morning I found it had dropped out overnight.  My laptop was conected by ethernet cable - no internet on lap top. All wifi devices off internet.  All lights on as usual on router but no internet connection.
Rebooted router and all now working fine.
What's going on ??
Message 13 of 15
DexterJB
NETGEAR Moderator
Hi @emmmr, as previously suggested above, we also recommend resetting the device to factory defaults after the firmware update. Let us know if the issue will persist after the reset.
Dexter
Message 14 of 15
emmmr
Guide
Message 15 of 15
Discussion stats
  • 14 replies
  • 6464 views
  • 4 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
