Orbi WiFi 7 RBE973
Reply
long delay before i can connect to NAS (wireless)
reckit
Follower
Hi There
Just bought a D7000 to replace a BT HH5 and I'm having issues connecting to my QNAP NAS using wireless. It can take up to 5 mins after connecting to the wifi before I can navigate to the NAS homepage or connect to the server.
The unit is recognised as a connected device in netgear genie and can be connected to instantly with a physical connection. After around 5 minutes it can also connect via wifi but before that I get site cannot be reached or server not found. I never had this issue with previous router
Any help would be appreciated
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 2
clithes
Prodigy
Re: long delay before i can connect to NAS (wireless)
Have you given the QNAP a set IP address ?
Also are you running the server on a schedule or do you have it on constantly ?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2414 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
