- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
D7000 Firmware Version?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have v1 of the D7000 on firmware version 1.0.1.50. An update scan from the router tells me it's the latest. The support page for the router offers 1.0.1.68 as the latest.
What's the story there?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D7000 Firmware Version?
Seems that despite the D7000 being a Nighthawk product & this being a Nighthawk sub-forum, I should have posted in DSL Routers.
Please move.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Greetings,
The FW versions offered in the Auto-Check and Update are not always the latest avaialble. This tool should not be relied upon. Not for checking or updating FW.
Always check the support portal for your model. D7000
Always upgrade manually from a computer connected directly to the router via ethernet
Manual update is the safest and most reliable way to upgrade.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks @shadowsports.
My first venture back to Netgear for some years & I remember different regions having different firmware versions. Didn't wan to risk bricking it but it's updated now.
Although it's a bit poor that the web GUI doesn't work properly. But then it is Netgear...
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's not that the Auto Check doesn't work, but we've seen that FW seems to get posted to the portal first then finds it's way to the update server later.
From an upgrade perspective, downloading and updating FW over wireless introduces a potential point of failure. It might work 10 times in a row, but if it fails, you usually end up with a bad or corrupt flash, and who has time for that.
Cheers
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd be fairly sure that there's been other updates. Can't imagine versions going from 50 to 68 in one hit.
Edit
I can see 60, 64 & 66 without looking too hard.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I received a Netgear email yesterday advising me that there was a firmware update to V1.0.1.68. I checked using Netgear Genie and found my device is running V1.0.1.64 so using the Router Update tab I checked for the latest update. It came back with no updates available. I opened a new browser window and went to http://www.routerlogin.net and entered my device info and followed directions to search for new firmware. Same result - no new updates available.
I want to make sure my device is running the current firmware - any suggestions? Thanks in advance!
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] V1.0.1.68. [...]
That's what I have.
> I want to make sure my device is running the current firmware [...]
Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
-antinode,
Thanks for your response. I was able to successfully install the new firmware.
Netgears original email directing me to www.routerlogin.net failed to turn up the new firmware. They should list the process that you outlined to visit netgear.com/support and then follow the release notes.
Thanks again!
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, they should make the bloody web check work!
