Orbi WiFi 7 RBE973
Reply
Need help finding the proper modem router for FTTH
emare
Follower
Hello,
I finally have received the parameters for my FTTH Tiscali internet connections.
I need to find a modem router model that can support all below parametrs.
Thanks a lot for your help.
Cheers
Emanuele
Parametri Internet e Voce:
PPPoE:      Fix
USER-VLAN:  8/35 in 802.1Q
user ID PPP (Internet) :
Password PPP (Internet) :
Username SIP (Voce) :
Password SIP (Voce) :
URI 1 :
outbound proxy/proxy server
• srv: srvmi.p.ims.tiscali.net
• fqdn: core2.p.ims.tiscali.net
• IP:
• Protocollo UDP: porta 5060
Protocollo Voip SIP RFC 3261
Dominio/Registrar ims.tiscali.net
Codec list g711alaw; g729
DTMF rfc2833 payload type 97 symmetric implementation
Fax g 711 pass-through (T38 disabled)
Session refresh Update method
PRACK Supported 100rel
MWI notify unsolicited ( subscribe disable)
CLIP PAI-FROM
Message 1 of 2
Re: Need help finding the proper modem router for FTTH
@emare wrote:
Hello,
I would worry about parameters. Your first quest is to find something that works with FTTH. Not sure that Netgear makes these.
Tiscali should have a list of compatible modems. There may also be a user forum where people talk about their equipment.
Message 2 of 2
Discussion stats
  • 1 reply
  • 1532 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
