Orbi WiFi 7 RBE973
Reply
Netgear D7000V2 stuck while more than 9 devices are connected (wired and wireless)
Nimrodi
Follower
I need help ! my Netgear D7000V2 stuck while more than 6-7 devices are connected (wired and wireless). its almost new, and i have this "Stucking" problem since i bouhgt it. whenever i connect more than 6-7 devices. the router stuck, and need to be reset. than it works for another 30 minutes and stuck again. for less devices (4-5) it works nice. im very disapointed from it.
i tried all of this settings changes with no luck:
**Firmware**
1. upgrage to 66 firmware --> Factory Reset --> configure my settings (see below**).
2. downgrade to 56,62,64,38 firmware --> Factory Reset --> configure my settings (see below**).
**Wifi**
3. i changed my wifi channel to 6 or 11. there are no collision with neigbours.
4. uncheck Enable Implicit BEAMFORMING.
5. i disabled Co-Existing 20/40 Mhz. and left only 20Mhz.
6. i change Wifi to Short Preamble
7. i changed Fragmentation lentgh from 2346 and CTS from 2347 both changed to 2034.
**WAN**
8. i changed MTU from 1492 to 1400.
it took me weeks to make and check each step. i realy dont know what to do. any ideas ?
i realy hope a technition from netgear will help me to solve that issue.
Thanks for whom will answer!
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 390 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
