Orbi WiFi 7 RBE973
Reply
Nighthawk d7000
Madmick153
Follower
Nighthawk d7000
When trying to access modem with routerlogin just comes up configuring the internet connection wont go to modem page how can i get around this
Thanks
Model: Dual Band
Message 1 of 3
Re: Nighthawk d7000
Thanks
Is this with a wired connection to the D7000?
What does "modem page" mean to you?
When connecting the device for the first time, the startup"genie" kicks in. Is this a new installation of this modem/router?
This may help:
How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support
and this:
If you cannot login to your router | Answer | NETGEAR Support
You have posted your message in the section of this community given over to Mobile Routers, Hotspots & Modems. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but DSL modems are very different from mobile modems, so you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
DSL Modems & Routers
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
Message 2 of 3
antinode
Guru
Re: Nighthawk d7000
> Nighthawk d7000
   D7000[v1] or D7000v2?  Look for "Model" on the product label.
> [...] just comes up configuring the internet connection [...]
   What, exactly, does it say?
   Isn't there an option to configure it manually (which should get you
past the set-up wizard)?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 628 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
