× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
CM2050V Availability
pktierney99
The CM2050V cable modem is the only model shown on the Xfinity site for 1.2Mbps and voice. But, I can't find it anywhere for purchase. Does anyone know if it is truly for sale and where to get one? I've tried calling Netgear multiple times and only get a technician who has no idea. I can't find anyone in Sales to talk to about it.
Message 1 of 7
Guru
Re: CM2050V Availability
They tend to go out of stock rapidly when they become available. covid has caused many shortages.
Message 2 of 7
pktierney99
Thanks. I was assuming that was the case. I'm still trying to get ahold of the Netgear Sales Team to see what options exist.
Message 3 of 7
Guru
Are you wanting the 2.5g port?
otherwise your other option is the cm1150v
Message 4 of 7
Guru
it uses wan port aggregation for up to 2gig speeds. 1gig if not using wan port aggregation.
Message 5 of 7
pktierney99
The real issue is Xfinity -- they are stating the CM1150V won't support their 1.2Mbps stream. In part I think because the firmware update required isn't supported for the 1150V (I've also seen that in the Netgear literature). I want to connect it to a mesh network and keep the max data transport speeds at all three of the nodes (hard wire to the ethernet ports on the mesh network). I don't think the 1150V will support this option at the 1.2Mbps speed.
Message 6 of 7
Guru
I think @CrimpOn maybe has a cm1150v? I don't one for specifics.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 952 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
