- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How do I get gigabit speed to my cable modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, all,
I just installed my new Nighthawk X4S router. Downloaded the latest formware update in the process. It is connected to a Motorola MB7420 cable modem for access to Comcast. Both of these deveices are gigabit connection capable. Is there a way on the Nighthawk to initiate gigabit speed on the WAN connection to the modem? Any insight would be much appreciated!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Log into your X4S and click on Show Statistics in the Advanced tab. If the status of the WAN port shows 1000M/Full, then you are golden. Otherwise, check your cable; cables can go bad.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How do I get gigabit speed to my cable modem?
Excellent! thank you!
