× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
R6220 LAN setup
cearlp
Tutor
R6220 LAN setup
Does the R6220 support ip reservation?
If so, when you reserve a particular ip address for a particular device shouldn't that device show that ip adress in it's configuration?
for example: I reserve ip 192.168.1.5 for device xxx. but an ifconfig on the device shows it's original ip address of 192.168.1.4 hardwired and 192.168.1.8 wifi connected.
Message 1 of 3
Accepted Solutions
Guru
Re: R6220 LAN setup
try rebooting the pc and router at the same time. The router isn't immediately going to switch the device over when you reserve the IP address.
Message 2 of 3
All Replies
Guru
Re: R6220 LAN setup
Message 2 of 3
cearlp
Tutor
Re: R6220 LAN setup
Thanks for the info, It worked as i hoped it would.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1212 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
