× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
R6220 NetGear WPS blinking
Akateko
I unchecked the wps pin configuration in the router settings that says enable pin code as described in a recent artice from netgear directly. Although the wps light is still blinking. So is wps going to stay on? just as a push option instead of the pin option to avoid brute force?
Message 1 of 6
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: R6220 NetGear WPS blinking
Hello @Akateko,
Welcome to the community!
WPS light will still be blinking slowly even if you uncheck the "Enable Router's PIN" and even if you push the WPS button at the back of the router, the PIN will still not work.
Hope this answers your question.
Message 2 of 6
All Replies
ElaineM
Hello @Akateko,
Message 2 of 6
Akateko
Thank you for the response. Although is it possible to completely turn off wps?
Message 3 of 6
ElaineM
@Akateko If you're talking about the WPS light, there's no way to have it completely turned off.
Message 4 of 6
Akateko
I thank you much!
Message 5 of 6
ElaineM
@Akateko You're welcome!
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 6405 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
