× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WNDR4300v2 Parental control stopped working
_AW
I have a very similar problem to this post: https://community.netgear.com/t5/General-WiFi-Routers-Non/wndr4300v2-parental-control-not-working/m-...
I was on FW:1.0.0.56.
I had parental controls enabled on my router, with settings on netgear.opendns.com
It worked fine.
I tried to change the access level of a particular device using the Network Map in Genie on my Android phone. (My apps are autoupdated, so I am on the latest app version).  My router seemed to go haywire for a little bit.  I don't remember clearly what all happened.  This is the first time I noticed that Netgear has been making changes to parental controls.  It seems that they are trying to move more of it into the app.
Well, after that point, once I got my router working again, which took a reboot, parental controls have never been the same.  If I switch on the controls, it completely stops all web trafic from everything connected.  I have tried all kinds of things by now with still no success.
I have upgraded my router to FW:1.0.0.58, did a router reset to default settings, I signed out and back into my OpenDNS account on Genie.
At this point, still, if I enable parental controls in the app NO web pages load.  My filter level is custom with 19 filters choosen.  Also, often if I try to change filter level in the app I get "Action failed try again later".  It has worked at one point, but right now it will not let me change my default filtering level.
When I reset to factory defaults, I then restored settings using a back up file.  Is it possible that could restore whatever is causing the problem?
This is really annoying as I have spent several hours on it, read several posts, but have not found a solution.
Model: WNDR4300v2|N750 Wireless Dual Band Gigabit Router
Message 1 of 5
Accepted Solutions
_AW
Re: WNDR4300v2 Parental control stopped working
I was able to work around the problem by using the Windows version of the Genie App.  From that app I was able to setup parental controls again.  I still cannot use the parental controls in the Android Genie App and Netgear is testing to see if they can duplicate the problem at this point.
Message 4 of 5
All Replies
_AW
I reset my Genie App on my phone.  Now I cannot even log in to the opendns account in the Genie App.  I tried many times, I verified my password by logining on to netgear.opendns.com.  I give up for now. Smiley Mad
Message 2 of 5
DexterJB
NETGEAR Moderator
Hi @_AW,
I have sent you a message. Please check your inbox.
Dexter
Community Team
Message 3 of 5
_AW
Message 4 of 5
_AW
I needed to come back and say that my problem did not go away for more than a day.  The problem was never solved even though tech support got involved.  I spent many hours trying the same things over and over.  Reseting to factory defaults.  Uninstalling the app.  Re-uploading the same firmware.
Bottom line, it is a broken system that they could not help me get working.  They are pushing for parental controls to go to a monetizing system.  I wish they would have just left things as they were working.  It will be a very long time until I try a Netgear product again.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1451 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
