× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WNR2000v5 Firmware Version 1.0.0.34 doesn't install
DVE44
WNR2000v5-V1.0.0.34.img downloaded from NetGear Support on 2015-09-22 failed to install.  I am currently using v 1.0.0.28.
As an aside, checking for new firmware from the GUI, reports "No new firmware version available."
Message 1 of 10
Accepted Solutions
DVE44
Re: WNR2000v5 Firmware Version 1.0.0.34 doesn't install
Thank you for your response.
As per RonO, Genie also reported "No new firmware version available," when I checked for new firmware. I'm currently using v. 1.0.0.28. I again downloaded the zipped firmware from support using a different browser and tried to install the .img file using the same browser (Microsoft Edge, which replaced IE in Win 10).  I previously used FireFox. Still it would not update.
BUT -- resetting the router did the trick. My router is now the proud owner of v 1.0.0.34! 🙂
Thank you for your suggestions!
DVE44
Message 4 of 10
All Replies
ElaineM
NETGEAR Employee Retired
Hi @DVE44,
Welcome to the community!
Did you try to use a different web browser? Also, try to re-download the firmware just to be sure that it was not corrupted.
If you can't still install, try to reset the router by using a paperclip to poke the reset button for 10 seconds.
Resetting will erase all the settings, therefore you will have to reconfigure the router.
Let us know what happens.
Message 2 of 10
RonO
I have the same problem with ...34.  Also when I try to download it with the Genie it only offers ver ...28
Message 3 of 10
DVE44
DVE44
Message 4 of 10
ElaineM
@DVE44 Thanks for the update! Glad to hear that it's now upgraded.
@RonO Will forward that to the engineering. For now, I suggest that you manually download the firmware and install it from there.
Message 5 of 10
RonO
As DVE44 did, I manually downloaded, unzipped, and applied the ING file and it thought about it for a while and then failed with the same message DVE44 got.  I am not comfortable resetting the router, but if the Genie is not able to fetch 34 soon I will have to try it.  Do you have an idea of when that fix might be done?
Message 6 of 10
DVE44
Hi RonO,
I didn't reset my router by sticking an open paper clip in a reset hole, but just powered down the router. There's a black power button on the back of the router, below the power cable. Press it to turn off the power, wait 10-15 seconds, then press it again. Wait for the three LEDs on the front to turn green and try the install again.
I used to power down my router every day, but from a master switch which controlled power to all of my computer gizmos (a desktop, a printer, audio system, etc.) without a problem.
Good luck,
DVE44
Message 7 of 10
RonO
Hi DVE44,
Finally got around to trying your solution and I worked as you said!
Thank you very much for taking the time to stear me in the right direction.
Very much appreciated.
RonO
PS, Netgear, you could do a better job.
Message 8 of 10
RonO
xfireman wrote:
"Did your download show corrupter IMG Disc" in "Wireless N Routers"
No errors, no problems on my final try.  I used the IMG file that came with the zip downloaded more than a week ago.
RonO
Message 9 of 10
ElaineM
The auto firmware update on Genie should now be working.
Thank you for reporting and your continued support.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 6242 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
