- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WNR614 poor speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Team,
I am facing slow speed on my wifi router netgear WNR614 model as it is working fine if we connect directly from router to the laptop. Could you please check the reason for the slow speed of the router ?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WNR614 poor speed
Welcome to the community, @visakhv
Just to verify, you're having slow wireless or wired speed?
What's the speed when you connect your laptop to the router?
What's the speed you're expecting?
Is this working previously?
If you're having problems with the wireless speed, do you have the latest wireless driver installed on your laptop?
What's the model of the wireless adapter?
Did you try changing channel on the router?
Make sure that you avoid other wireless devices that may interfere with the signal such cordless phones, microwave ovens, baby monitors, etc.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am having slow wireless speed as I am getting good speed by connecting network cable directly to the laptop. Direct connection speed is 60mbps and wireless speeed is not even 10mbps.
10mbps
I am expecting minimum 25mbps in router .
I was working till last week.
Latest driver is installed in laptop. We tried in mobile devices also, getting less speed there also.
Netgear WNR614-100INS
Channel configuration is default.
Apart from mobile devices there are no wireless devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try to reboot your device.
If it does not work factiry reset.
If you do still have an issue call me back!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you check on the wireless settings?
Did you checked the mode?
Keep me posted!
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
Which mode you are talking about ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
make a picture like this to help me understand what is going on plz.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am in India Bangalore location.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does your device is still under warranty?
The support center is only on internet and so you have to submit a case.
I love the food in your country!
- Mark as New
- Bookmark
- Subscribe
- Permalink
The product is 8months old and I don't think about the warranty.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can try ot login to the router's interface page by tying www.routerlogin.net
If asked for username: admin
password: password
Change the wireless channel to 09, 06, 11. Check for hte connection.
Try to update he firmware version.
Change the settings by connecting the computer wired to router.
Also in wireless device's probably you would get half the speed which you get from wired.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I mean if we change to channel 11, what it does really ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'll explain the procedure again
login to the router's interface type www.routerlogin.net
password: password
wireless settings menu
wirerless network 2.4Ghz section
Channel on auto
mode on the max
wirerless network 5Ghz section
Channel on auto
mode on the max
keep me in the loop if it does not solve the issue!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did a mistake on this psection of procedure
Channel on auto
mode on the first one.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wireless Network (2.4GHz b/g/n)
Name (SSID):
Achi
Channel:
Mode:
Enable SSID Broadcast
Enable 20/40 MHz Coexistence
Security Options
None
WPA2-PSK [AES]
WPA-PSK [TKIP] + WPA2-PSK [AES
This is the wireless settings in my router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can switch back to auto channel.
Can you tell me on your router if you can overpass the 300Mbps on the mode?
If yes max it out.
Make some tests and keep me in the loop!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am getting intermediate speed on router like sometime I get 46mbps and sometime it goes to 8 Mbps.
