sirlancelot33's avatar
Dec 22, 2017
Parental control not working
Downloaded Netgear Genie.  Router is on and running (using it now), but when I try to eneble Parental Controls in Genie, it tells me "Internet is not available.  Connect your router to the Internet."  WTF?
  • Hi sirlancelot33,
    1. What is the firmware version of the router?
    2. Please try using another device (computer, Android, iOS).
    3. Have you tried resetting the router?
    Dexter
    Community Team
    • Firmware has the latest version.  I don't have another device.  Of course I have reset and restarted the router.
      Anyone have any real solutions?
      • db4545's avatar
        db4545
        Was there a solution? I'm having the same problem. Opening Parental Controls through the Genie program on Windows does not work. It either says I'm not connected to the internet (when I am), or the OpenDNS login fails (it's an existing account I have verified in my browser).
        R6700v3
