- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7800 remote access with genie
- Mark as New
- Bookmark
- Subscribe
- Permalink
How do I get the remote access to work when I am not on same network. I have he genie on iPad and it works just fine locally but does not show up when off network
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all,
You can check the link below for the steps on how to setup the Remote Login feature of the NETGEAR Genie app.
http://kb.netgear.com/app/answers/detail/a_id/26109
Dexter
Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7800 remote access with genie
Yeah I'm having the same problem. Lost wifi altogether (but still had internet) when I upgraded firmware to .24 so downgraded to .22 and got wifi back but no RA. Did all the usual, reset factory defaults, uninstalled genie on iPad and iPhone but no luck. Curiously I can turn it on and off using 192.162.1.1 but no joy accessing it remotely. I've tried having it off and turning it on using Genie no luck. Tried the other around and still nothing. Not having any RA problems with R9000 at different address. Both NBN Fixed Wireless.
- Mark as New
- Bookmark
- Subscribe
- Permalink
With the Android app you have to create a NETGEAR account. There is an explanation of this in the manual, which should be at the end of this link:
genie Landing Page | Apps | Discover | Home | NETGEAR
Check page 7.
This probably applies also to the iVersion.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all,
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Finally got a chance to do as you suggested and it worked. You wouldn’t have thought so though. Genie (PC version) brought up all sorts of errors like password incorrect etc but somehow (miraculously) I now have RA to both D7800 & R9000 via iOS App. Thanks.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
