- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyShare not allowing access to my WD drive since I ejected the drive
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a WD terabyte drive and used the ReadyShare feature, I tried to eject the drive from the readyshare application and also from my Macbook. Wasn't sure if it had been ejected or not, I unplugged the drive from my router and tried to use in my Macbook, drive only flashed with a fast blinking. Plugged the drive back into the router and was able to access files. I then ejected the drive from the router and tried on Macbook again, same thing, fast blinking on HD and will not connect to either the router or Macbook. I think there is something wrong in the ReadyShare application that is blocking the MAC Address on the HD from connecting.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyShare not allowing access to my WD drive since I ejected the drive
Hi @Airpro360,
1. You mentioned "HD and will not connect to either the router or Macbook". So, is the hard drive inaccessible on both the router and directly to the computer or is it just when connected to the computer?
2. What is the file format of the hard drive?
3. Have you tried connecting the hard drive to another computer?
4. What is the model number and firmware version of the router?
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Airpro360,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
I somehow finally ejected the external drive from the router. Yes, fortunately through the community. I find it sad that Netgear will only support their routers for 3 months . I’m sure that will be a deciding factor when purchasing my next set of routers and networking equipment.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Airpro360,
I would like to confirm if the issue was resolved. If not, your response to my previous inquiry would help us isolate the issue.
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Betreff: ReadyShare not allowing access to my WD drive since I ejected the drive
I have the same problem!!!
I can't use my garddrive on my mac anymore, after having attached it to my Netgear Router. On my mac the harddrive (attached with usb) blinks but does not appear anymore.
Please help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Betreff: ReadyShare not allowing access to my WD drive since I ejected the drive
Hi @pileo,
1. What is the model number and firmware version of your device?
2. What is the model number and capacity of your hard drive?
3. Can the hard drive still be detected when connected to the router?
4. What is the file format of the hard drive?
5. Can the drive be detected when connected to a Windows PC?
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
