- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Router not awnding out wifi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @nrscalf10,
Welcome to the community!
1. What is the model number of your NETGEAR device?
2. Please make sure that the router is set to broadcast the SSID (WiFi name) on the router UI. This link may help.
3. If your router has a physical WiFI on/off switch, you can try pressing that for 2 seconds and see if the issue will persist.
Dexter
Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @nrscalf10,
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Router not awnding out wifi
Hi @nrscalf10,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Mdraper21,
Please see my previous comment about making sure that the WiFi is set to be broadcasted. Also, check if pressing the WiFi on/off for 2 seconds will fix it. Sometimes that can be pressed by accident turning the WiFi off.
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can access the UI of the router and make sure that the SSID broadcast is checked. The link below might help out.
http://kb.netgear.com/app/answers/detail/a_id/24095
If that proves to be difficult, then a factory reset may be the only option.
Dexter
Community Team
