prakashch's avatar
prakashch
Firewall FVS318Gv2 not responding connection to WAN from Verizon FIOS router MI424WR-GEN3I
Hi,
I am unable to connect the Firewall to the verizon router. The WAN port does not show the LED lit up, nor does the verizon router detect the Firewall device.
If I connect the Firewall WAN to the NETGEAR WNDR3800, it will happily accept the connection.
I also tried to connect the Firewall WAN to Linksys E2500. Here again it would not light up the LED, nor would the linksys router detect the device.
Am I missing something?
I would appreciate your help.
Prakash
  • Hi DaneA,
    Thank you for the explaination.
    This is what I had tried after I had replied last.
    1. I tried the Factory reset & tried to connect to Verison MI424WR-GEN3I. This would not til up.
    2. I again retried Factory reset & connected to the Linksys. I could see one Green & one Amber. The Linksys did not show the new device, nor did the Firewall FVS318Gv2 show any WAN IP.
    3. Even without restart I connected the WAN to WNDR 3800. I could immediately see 2-Green LED. The Firewall showed up WAN IP.
    I do not understand what is the difference here between these 3 routers.
    Thank you,
    Prakash
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi prakashch,
    Kindly answer the questions below:
    a. Is the FVS318Gv2 working fine before?
    b. Have you tried to perform a factory reset on the FVS318Gv2?
    DaneA
    NETGEAR Community Team
    • prakashch's avatar
      prakashch
      Hi DaneA,
      thanks for responding.
      -Yes
      No.
      Sure I could take a back up of the current settings and try this. However then, it does work if this is connected to NetGear WNDR3800. I do not have the firewall set with static IP. (set to Get Dynamically from ISP). Any other possible reasons that you can think of?
      Thanks once again.
      Prakash
      • DaneA's avatar
        DaneA
        prakashch,
        You mentioned that  the WAN LED of the FVS318Gv2 won't even lit up when connected that is why I am suggesting you to kindly perform a factory reset on the FVS318Gv2 then try to reconfigure it from scratch.  Its because the WAN LED should at least lit up orange/amber if it detects that there is no WAN connection.  Otherwise, the WAN LED should lit up green if there is WAN connection detected.
        DaneA
  • The Verizon FIOS router is a bit of a funny device.  What exactly are you trying to do?  Because it may need more configuration on the FIOS gateway to work.
      prakashch
      Hi SamirD
      Earlear this Firewall was configured on my netgear WNDR3800. The WNDR3800 was connected to FIOS. Evey thing was working fine. However to connect to device under the firewall I had to make a VPN connection while connected to WNDR3800. To avoid all this I thought of moving the Firewall to one level up so that I wound not have to connect via VPN while connected to WNDR3800. Also, that way I would be able VPN from outside world.
      As you just said, I did find some blogs that described the issues with configuring FVS318Gv2 with FIOS. I then deviced to get something to bridge the FIOS & the FVS318Gv2. So, I got the linksys. I was then trying to configure as follows
      FIOS > Linksys > FVS318Gv2 > WNDR3800.
      As I described in my previous posts, I was unsucessful in configuring the FVS318Gv2 even with the linksys. Thus, making me wonder if there is some special connection requirement for the firewall.
      Thanks
      • SamirD's avatar
        SamirD
        Prodigy
        It has been a few years since I dealt with the FIOS gateway, but I think I actually ended up setting the fvs in the dmz to get it to work properly.  As far as the wan light, that is a bit of an oddity, but I would check the settings in both the FIOS and fvs and set them manually to the same speed/duplex if need be.  Sometimes autonegotiation still doesn't work.
ProSupport for Business
