ACB-Holmen's avatar
ACB-Holmen
Netgear ProSafe VPN Client
I am using the Netgear ProSafe VPN client to connect remotely to the network. This works so far. Now I have a new laptop and I am not able to activate the Netgear VPN software. Always says "internal error - try again later". This software has a full 5 users free - not one used so far. What could be wrong?
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    ACB-Holmen,
    Welcome to our community! :)
    It seems that you are having issues applying for your VPN Client License. Do you see any error code on your VPN client? May you be able to send me the license key via private message so that we could check it on our end?
    John
    NETGEAR Community Team
    • ACB-Holmen's avatar
      ACB-Holmen
      Hi John,
      it says error code 70 - internal error.
      Please see attached screen shot - in German I am afraid. Screen shot
      • JohnC_V's avatar
        JohnC_V
        ACB-Holmen,
        Please try to disable first the firewall and the anti-virus of your PC then try to activate the license again. Please also send me the license key via private message so that we can check it on our end and have it reset.
        John
ProSupport for Business
