FHo
Apr 22, 2016Aspirant
Problem ubuntu Client - openVPN - SSL VPN connecting to proSafe / FSV318
Hi,
I want to set up a Simple SSL VPN tunnel. One Linux client - connecting to the FVS318N.
The web-SSL is not suitable for me, because the java applet uses root access, but I normally do not use the root account.
What kind of client do you recommend for linux clients? Do you have a brief installation description for it?
I am trying to use openVPN but get the following output from openVPN:
Fri Apr 22 10:58:18 2016 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Apr 22 10:58:18 2016 TLS Error: TLS handshake failed
I cannot see anything in the VPN SSL Logfile on the FVS318.
Best regards,
Florian
- Retired_MemberApr 22, 2016
Hi FHo,
You should probably use IPSec VPN.
https://help.ubuntu.com/community/IPSecHowTo
Hope this helps ;)
- Retired_Member
Hi FHo,
Hope this helps ;)
- FHoAspirant
Actually - the best was to take IPsec with shrew Soft VPN
