- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
24 port managed ethernet switch
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am looking for a managed 24 Gigabit Ethernet port multilayer switch that works on layer 2 and layer 3. The switch must have redundant power supplies. Also it must be 19” rack mounted taking up 1U of rack space and 18” depth or less. In addition the switch must meet MIL-S-901D Grade B shock. Also the switch must support the SSH v.2 and GLBP protocols. It must be Cisco IOS compliant with a serial console access that supports RS232. In addition it must be FCC class B compliant.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 24 port managed ethernet switch
Hi @navyguy,
Welcome to the community! 🙂
As far as I have checked the data sheet of NETGEAR ProSAFE Managed Switches, it is not indicated that it has a rating of MIL-S-901D Grade B shock nor it is a Cisco IOS compliant. It could be possible that you are looking for a Cisco managed switch not NETGEAR.
Let me just share the data sheet below of both NETGEAR ProSAFE M5300 and M4300 series managed switches:
ProSAFE® M5300 Next-Gen Edge Managed Switches
ProSAFE® M4300 Intelligent Edge Managed Switches
DaneA
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does anyone know the lower bound for relative humidity for the Netgear ProSafe M5300 switch series? The upper bound is listed but not the upper bound.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does anyone know the power consumption for the models listed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@navyguywrote:Does anyone know the power consumption for the models listed?
You can derive the max continuous power requirements directly from the heat dissipation numbers.
@navyguy wrote:Does anyone know the lower bound for relative humidity for the Netgear ProSafe M5300 switch series? The upper bound is listed but not the upper bound.
The lower bound is unspecified because there is no requirement for any humidity for the switch operations - so take it as 0%.
I hope you can get this confirmed officially from Netgear - I'm not keen to get imprisoned for "providing false information" when travelling abroad. However, have done several military projects including maritime military installations, some inherited special packing of IT industry standard systems for naval similar mil 19" installations. Good luck for yours!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you, @schumaku this is correct.
@navyguy I would consider M4300 series instead, which has replaced M5300 series. Max power consumption in Watts is listed for every model in the M4300 datasheet (search page 49). As @DaneA mentioned, I would be cautious with MIL-S-901D Grade B or Cisco IOS compliance requirements. If these requirements are mandatory, then you shouldn't consider NETGEAR M4300 series.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What shock and vibe standards does the M4300 switch series meet?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is a ballpark estimate on the EOL for the M4300 switch series? We are replacing our current switch because it has reached its EOL. So we don't want to replace this switch with a new one that has a EOL within 3 years.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does the M4300 ethernet switch series have stacking capablity of stacking switches that are more than 3 meters apart?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does the M4300 ethernet switch series have redundant fans?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@navyguy I hope you can read M4300 4-page Product Brief (rapid overview) or M4300 Brochure (more complete overview) or the comprehensive M4300 datasheet (exhaustive information) under the M4300 product page Resources tab.
Let me answer your questions:
- M4300 is flexible enough for mixed stacking between 10 Gigabit and 1 Gigabit models, using any 10G port with any media type (RJ45, SFP+, DAC cables). There is no "dedicated" stacking port or stacking media. You can enable Stacking Mode on any 10 Gigabit port on any model (up to four 10G Stacking Ports on each Gigabit switch; and up to sixteen 10G Stacking Ports on each 10 Gigabit switch)
- M4300 does't have redundant fans, only dual, redundant and hotswap PSUs (full-width models) or modular, serviceable PSU (half-width models)
- There is no EOL communication on M4300 models. The M4300 product lifecycle is still around the "introduction" stage and the "growth" stage. We are adding new models to this family (see the stunning new M4300-96X, the world-first modular 10G switch scaling up to 96 ports of 10 Gigabit Ethernet by multiple of 8 ports). I wouldn't worry too much about the EOL at this stage, although I cannot officially comment nor commit for a pre-defined remaining life time of any sort.
- M4300 models don't comply with Industrial-grade or Military-grade shock standards or vibration standards. M4300 models are built and tested for normal office and server environments. Our strict reliability testing procedures include industry-standard "Shock" testing with accelerations up to 40G, as well as "Vibration" testing with frequencies up to 100Hz.
Thank you for considering NETGEAR M4300 series. You can contact NETGEAR Sales representatives at your convenience as well, just send an email to sales@netgear.com
