AW_GearNet's avatar
Jul 22, 2016
EOL for Java - new FW for GS724Tv4
GS724Tv4 ProSafe 24-port Gigabit Ethernet Smart Switch, 6.3.1.11
I have a GS724Tv4 ProSafe 24-port Gigabit Ethernet Smart Switch, 6.3.1.11.
The FW uses partially Java for "Device View" and needs java plugin.
Java is EOL!
https://www.java.com/en/download/faq/chrome.xml
What happens with device view in FWGS724Tv4? Will there be an other solution from Netgear?
Rgds
AW
1 Reply
  • AlexPe's avatar
    AlexPe
    NETGEAR Expert
    Dear Aw,
    It should work in internet explorer. If you need to use Java you can use Java on Firefox. Its jus EOL on Chrome.
    Thanks,
    AlexPe
ProSupport for Business
