Sunny_Amigo
Jun 01, 2016Follower
GS105V5 unable to connect to router
Hi dear NetGear team,
1. I install Prosafe Plus Configuration Utility for GS105 ( not sure that for the GS105v5 because didn't find such )
2. Accept all Windows firewall notification that pumps up
3. Plug in on cable to my working router ( D-link DIR-300 ) and one to my PC ( win 8.1. )
4. Power Up NetGear GS 105 ( it was done at first place )
5. Also donwload GS105Ev2_V1.4.0.6 zip but don't know how to install it
6. Reboot my PC
7. Reboot my DIR-300
8. Yes, I forgot to mention that I start up ProSafe Plus Config Utility press refresh button and the app said to me "No switch exist in the local area network! "
and still can access internet only through DIR-300 wi-fi the Win gives me notification in "NetWorks " "Connections" - Unidentified network
What should I do in order to get access to the internet through the GS105v5 in my case ? All cables are working they short (1 meter ) . Connection to the internet provided by the DIR-300 through wi fi is working all the time. My operation system is Win 8.1. Should I install something ? Like the GS105Ev2_V1.4.0.6 or something ?
for me info please take a look on this pdf
https://drive.google.com/file/d/0B-2xpKXuvT70RzB6ckpPVHptRk0/view?usp=sharing
Sunny
- JohnRoNETGEAR Employee Retired
Hello Sunny_Amigo,
Welcome to the community!
The GS105v5 is only a pass-through plug-and-play switch. It does not require any software or firmware to run. It is basically just an extension to the router's ports. I saw the contents of the link and it looked like the switch was installed properly, If the LEDs are blinking it means that it is detecting a connection (activity). My question is when the laptop is plugged into the D-Link modem do you get a connection?
Thanks,
Hi Sunny_Amigo,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
