- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How to make network failover or redundancy?
- Mark as New
- Bookmark
- Subscribe
- Permalink
HI
-------- Line 1 -----------
Rounter ----| | ---- Network swich ----- PC
-------- Line 2 -----------
I need to make
Line 1 and Line 2 connect to network switch
When Line 1 disconnect then Line 2 take over.
I knew when line 1 and 2 connect to same switch then network loop.
Any better IDEA?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How to make network failover or redundancy?
Hi @parkck ,
Welcome to community,
There is two plans for you.
Plan A : Lyaer 3 plans: (Need you switch to support routing feature)
You can configure static or dynamic routing to achieve network redundancy and load sharing through routing priority configuration and routing strategy on both links
Plan B: Lyaer 2: (Need you Router to have LAN port and support STP feature)
Connect the two lines directly to the router's LAN port,Through the STP protocol, loop detection can be carried out and one link can be interrupted during operation to realize redundancy of two links
If you can provide netgear switch model and router model, I can offer more Suggestions
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for reply this.
This is Local network (Class C) 2 strusture communications each others not such as 2 internet connections.
How about loop network/protocol? Do i need CISCO?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @parkck ,
Plan C:
If there was only one Internet WAN port in your Router, i think you do not need two links from switch to router.
For example(Simple network):
Internet --------- Wan port-------Router-----192.168.1.0-----Swtich=========192.168.1.0 / 192.168.2.0
Key point:
Can you provide the detailed model of the router? It affect what scheme should be used if you really need to connect two links.
BTW:
For Layer 3 plan you can choose netgear switch that support routing, such as Smart switch(F4 GS728TPP) or Manage Switch M4300...etc
For Layer 2 pan you can choose netgear switch that support STP, such as Smart switch F4 or S350...etc
- Mark as New
- Bookmark
- Subscribe
- Permalink
There's also a third option: if your router supports LAG and your switches support stacking, you can run one line from each stack member to the LAG on the router, then one line from each stack member you wish to have highly available on the other side. Failover is usually fastest with this method and you aggregate more bandwidth, with the downside being that scheduled maintennace takes down the entire switch stack at once.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for reply
I'm still not sure
This is my model
Frontier DSL MODEL & Router Port #3 Line 1 - Wireless AP 1 - Bridge 1 - Managed Switch 1 Port #23
Frontier DSL MODEL & Router Port #4 Line 2 - Wireless AP 2 - Bridge 2 - Managed Switch 2 Port #24
Switch Port #23, #24 configure to LAG.
Is this working?
