tlex
Mar 06, 2017Aspirant
M4100 dhcp reservation
Good day !
So my M4100 is set at 192.168.1.1
I made a dhcp scope (scope1) dynamic for 192.168.1.0 / 255.255.255.0
In the dhcp server setting I made an exclusion from 192.168.1.1 to 192.168.1.99.
Everything works fine except that now I'm trying to make an ip reservation for a specific device.
I made a new scope (scope2), manual, entered hardware address (MAC) and client ID (MAC + 01: in front of it).
the device still grab an IP from the main scope (scope1) ignoring the manual reservation from (scope2)...
I just dont understand why.
I tried to specify the ip address for the scope 2 to be with the exclusion range and also outside the exclusion range without success...
Any idea ?
Thanks for your help !
Logs goes like that :
<14> Jan 14 23:03:46 10.32.50.3-1 DHCPS[51097332]: dhcps_main.c(2298) 2 %% Lease now ACTIVE. pool DHCP_Scope1, ip/mac=192.168.1.100/00:22:6c:5b:ab:62 Expired/Unused Entries=0/252
<14> Jan 14 23:03:46 10.32.50.3-1 DHCPS[51097804]: dhcps_main.c(2275) 1 %% Lease Offered. pool DHCP_Scope1, ip/mac=192.168.1.100/00:22:6c:5b:ab:62
1 Reply
- DanielZhangNETGEAR Expert
Hi tlex,
Welcomet to NETGEAR community!:smileyhappy:
Maybe you need to set same configuration for the manual pool as following screenshot.
The Client ID is (01:MAC Address of DHCP client)
The Hardware address is none.
The Host number is the IP address that you want to assigned. (such as: 192.168.1.254)
The Host mask should be same as routing interface(such as: 255.255.255.0)
May the solution help you.
- Feb 21, 2022Retired_Member
