MarkThackeray's avatar
Aug 07, 2021
M4300 blocking layer 2 PTP messages
Hi,
I have been trying to use a couple of Blackmagic Design IP Video 12G usits with this switch.  They use 1588-2008 but on layer 2 (have raised this with them, but I doubt they will change it to layer 3 any time soon), and this traffic does not pass through the M4300 series switches.  I have confirmed this with both the units (all set themselves to Master) and with the Meinberg PTP Track Hound software running on a PC on the same VLAN.  Changing the VLAN to one with some Ravenna/DANTE/AES67 devices on (on layer 3 PTP) produces the expected traffic from these devices, so it would appear to just be the layer 2 traffic that is blocked.  PTP E2E TC is not enabled, IGMP is, device is not the querier.  Testing on another switch shows the traffic.
Firmware is 12.0.11.15
Any ideas how I can get around this?
Mark Thackeray
Broadcast Engineer, Royal Opera House, London
1 Reply
  • LaurentMa's avatar
    LaurentMa
    NETGEAR Expert
    Hi MarkThackeray ,
    Thank you for reporting this issue and sorry about it. Be sure we are going to help you fix it.
    I suspect a configuration issue if Layer 3 works but not Layer 2. In order to review we will need you to run the latest software. Please upgrade to 13.0.13.7 here https://www.netgear.com/support/product/m4300-52g-poe-plus%20550w%20psu.aspx#download
    Then, please export the tech-support file out of the switch (if using the Web UI, Maintenance/Export/HTTP File Export/Tech Support in the drop-down menu list). Please email us the file, there will be everything in it for us to find out the root cause. Please reach out to us at ProAVDesign@netgear.com. This team is committed to resolve any AVoIP issues!
    We will review your file tomorrow (Monday) morning first thing and get back to you.
ProSupport for Business
