Alexander-G's avatar
Alexander-G
Managet Switch sample running config
Hello Netgear Community,
I'm not familiar with configuring Netgear switches from cli, and have to achive following scenario:
GSM7252PS --> connected with two 10 GB interfaces as LAG with VLAN 1 / 6 / 200 to --> Cisco Switch
MGMT SSH access should be reachable by IP of VLAN6 (SVI)
ports 1-48 edge ports
ports 49-52 are stp ports in LAG
stp should be rapid
Could some one provide me an output of running config for similar device, please?
Thanks and Regards, Alexander
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi Alexander-G,
    Welcome to the community! :)
    I think it would be best if you will open an online case with NETGEAR Support at anytime.  Its because a NETGEAR support expert would be engage to you to provide you with technical assistance about the configuration of the GSM7252PS switch via CLI.
    DaneA
    NETGEAR Community Team
    • Alexander-G's avatar
      Alexander-G
      Hello DaneA,
      tried to conntact support, without success.
      They could not verify the warrenty for support...
      So it would be great if anyone could share the output of "show running" of a similiar switch with metioned features configured.
      Regards, Alexander
      • DaneA's avatar
        DaneA
        Hi Alexander-G,
        Hope that other community members that have the same scenario or even not exactly the same scenario would respond on this forum thread as long as its similar with the configuration you need as reference.  :)
        DaneA
ProSupport for Business
