wladimir50
Feb 06, 2018Follower
Monitoring VLAN with SNMP on MRTG
im trying to monitor traffic on my 5300 switch. It show traffic on ports without problems, but vlan graphs are generated but they are empty ...
any tips ?
i really appreciate you help.
- JohnC_VNETGEAR Employee Retired
Hi wladimir50,
Welcome to our community!
You may try to download the latest version of MIBs for your switch in order for it to work properly
I would like to have a follow up on this thread. Please let us know if everything is ok now or you still need further assistance.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
