AevnsGrandpa
May 27, 2016Aspirant
Need to limit bandwidth (rate) by port
While I chose this model, I am not bound by it. I am needing a switch where I can limit rate or bandwidth by port.
Here is the situation. My church streams and we currently have a 10Mbps down and 1.1Mbps up. If very few people are on the network (wifi) then the sustained streaming rate is fine with no caching or drop outs but get 60-100 devices hanging off the wifi and all deciding that now is a good time to download updates or something else then the stream is shot to...
I am thinkning that if I can limit the rate through the ports I connect the wifi devices to, this will limit how much of my "pipe" is used so I can keep the 1.1 Mbps upload untouched. Or if there is a way I can dedicate that much bandwidth always for upload only that would work to.
Please give me suggestions on both switches (the GS108E sounded like a nice one for not a lot of $$) and a good way to coomplish my needs.
Thanks,
Jeff
Hi AevnsGrandpa,
Let us know how it turns out. If it is working fine and this had answered your question, please mark the post as "Accept as Solution".
Thanks,
- AevnsGrandpaAspirantSo no one has any ideas, hints, put downs or anything?
- DaneANETGEAR Employee Retired
Hi AevnsGrandpa,
Let us know if you have questions. :)
DaneA
NETGEAR Community Team
- AevnsGrandpaAspirantThanks. I will but am on vacation now and that will have to wait!
- JohnRoNETGEAR Employee Retired
Hello AevnsGrandpa,
We'll come back to this post after a few weeks. Keep us updated. :)
Thanks,
- AevnsGrandpaAspirantWell it is in (105ev2) and i have it so all connections through it i have rate limited. We'll see!
Hi AevnsGrandpa,
Thanks,
I actually went with the GS105Ev2. I didn't need all 8 ports. Setr the rate to 1Mbps and then did speed checks on Wifi and wired and indeed it is limited!!
One more question, I have port 1 connected to the DSL modem and ports 2-4 to the other hubs and devices. Is ingress and egress in reference to port 1? So data from the DSL modem (the internet) in the ingress to port 1 and what it is to the other ports?
Thanks,
Jeff
