n__o_'s avatar
n__o_
Stack Port link down発生原因について
Thank you very much for your help.
I would like to discuss a problem with a device in use.
The stack configuration consisting of the following two SWs is suddenly stopping at Stack Port link down due to an error, and although there is no fatal impact from the stacking, it is happening once a month. If you have any idea about the cause, please let us know. We are considering requesting send-back maintenance if we suspect equipment failure.
Stack components:
①M4300-12X12F(sw1-1) Management   ②M4300-12X12F(sw1-2) StackMember
Firmware:
12.0.13.8 B1.0.0.15
ErrorLogs:
Jan 30 16:14:24 sw1-1 TRAPMGR[spmTask]: traputil.c(795) 4526 %% Stack-port link down: Index: 100 Unit: 1 Tag: 1/0/1
Jan 30 16:14:24 sw1-1 TRAPMGR[spmTask]: traputil.c(795) 4527 %% Stack-port link down: Index: 101 Unit: 1 Tag: 1/0/2
Jan 30 16:14:26 sw1-1 CKPT[tCkptSvc]: ckpt_task.c(363) 4529 %% Checkpoint message transmission to unit 2 failed for SNOOPING(44).
Jan 30 16:14:26 sw1-1 CKPT[tCkptSvc]: ckpt_task.c(363) 4530 %% Checkpoint message transmission to unit 2 failed for SNOOPING(44).
Jan 30 16:14:26 sw1-1 CKPT[tCkptSvc]: ckpt_task.c(363) 4531 %% Checkpoint message transmission to unit 2 failed for SNOOPING(44).
Jan 30 16:14:26 sw1-1 DRIVER[tap_monitor_tas]: broad_tx.c(428) 4532 %% HAPI tx_lplist: Failed on unit 1:Entry not found
Jan 30 16:14:26 sw1-1 DRIVER[tap_monitor_tas]: broad_tx.c(428) 4533 %% HAPI tx_lplist: Failed on unit 1:Entry not found
Jan 30 16:14:30 sw1-1 DRIVER[tap_monitor_tas]: broad_tx.c(428) 4534 %% HAPI tx_lplist: Failed on unit 1:Entry not found
Jan 30 16:14:30 sw1-1 DRIVER[tap_monitor_tas]: broad_tx.c(428) 4535 %% HAPI tx_lplist: Failed on unit 1:Entry not found
Jan 30 16:14:32 sw1-1 CKPT[tCkptSvc]: ckpt_task.c(487) 4537 %% Backup manager removed.
Jan 30 16:14:32 sw1-1 DOT1Q[dot1qTask]: dot1q_outcalls.c(315) 4542 %% Bad rc 1 in vlanNotifyRegisteredUsers for registrar 48, DOT1S
Jan 30 16:14:32 sw1-1 DOT1Q[dot1qTask]: dot1q_outcalls.c(315) 4543 %% Bad rc 1 in vlanNotifyRegisteredUsers for registrar 48, DOT1S
Jan 30 16:14:32 sw1-1 DOT1Q[dot1qTask]: dot1q_outcalls.c(315) 4554 %% Bad rc 1 in vlanNotifyRegisteredUsers for registrar 48, DOT1S
Jan 30 16:14:32 sw1-1 UNITMGR[unitMgrTask]: unitmgr.c(8160) 4539 %% No Potential unit to configure as Standby when unit 2 left
Jan 30 16:14:32 sw1-1 VOIP[tCkptSvc]: voip_ckpt.c(174) 4538 %% Backup unit gone
Jan 30 16:14:38 sw1-1 TRAPMGR[trapTask]: traputil.c(753) 4563 %% Entity Database: Configuration Changed
Jan 30 16:16:17 sw1-1 TRAPMGR[spmTask]: traputil.c(795) 4565 %% Stack-port link up: Index: 100 Unit: 1 Tag: 1/0/1
Jan 30 16:16:17 sw1-1 TRAPMGR[spmTask]: traputil.c(795) 4567 %% Stack-port link up: Index: 101 Unit: 1 Tag: 1/0/2
Jan 30 16:16:17 sw1-1 TRAPMGR[spmTask]: traputil.c(795) 4569 %% Stack-port link down: Index: 100 Unit: 1 Tag: 1/0/1
Jan 30 16:16:17 sw1-1 TRAPMGR[spmTask]: traputil.c(795) 4571 %% Stack-port link up: Index: 100 Unit: 1 Tag: 1/0/1
Jan 30 16:16:17 sw1-1 TRAPMGR[spmTask]: traputil.c(795) 4573 %% Stack-port link down: Index: 101 Unit: 1 Tag: 1/0/2
Jan 30 16:16:17 sw1-1 TRAPMGR[spmTask]: traputil.c(795) 4575 %% Stack-port link up: Index: 101 Unit: 1 Tag: 1/0/2
Jan 30 16:16:37 sw1-1 TRAPMGR[spmTask]: traputil.c(795) 4577 %% Stack-port link up: Index: 200 Unit: 2 Tag: 2/0/1
Jan 30 16:16:37 sw1-1 TRAPMGR[spmTask]: traputil.c(795) 4578 %% Stack-port link up: Index: 201 Unit: 2 Tag: 2/0/2
Jan 30 16:16:44 sw1-1 TRAPMGR[trapTask]: traputil.c(753) 4585 %% Entity Database: Configuration Changed
Jan 30 16:16:52 sw1-1 CKPT[tCkptSvc]: ckpt_task.c(423) 4622 %% Checkpoint operation to backup unit 2 complete.
Jan 30 16:16:52 sw1-1 CKPT[tCkptSvc]: ckpt_task.c(523) 4621 %% New backup manager selected, unit 2.
Jan 30 16:16:52 sw1-1 DOT1Q[dot1qTask]: dot1q_outcalls.c(315) 4624 %% Bad rc 1 in vlanNotifyRegisteredUsers for registrar 48, DOT1S
Jan 30 16:16:52 sw1-1 DOT1Q[dot1qTask]: dot1q_outcalls.c(315) 4625 %% Bad rc 1 in vlanNotifyRegisteredUsers for registrar 48, DOT1S
Jan 30 16:16:52 sw1-1 DOT1Q[dot1qTask]: dot1q_outcalls.c(315) 4628 %% Bad rc 1 in vlanNotifyRegisteredUsers for registrar 48, DOT1S
Jan 30 16:16:52 sw1-1 DOT1Q[dot1qTask]: dot1q_outcalls.c(315) 4630 %% Bad rc 1 in vlanNotifyRegisteredUsers for registrar 48, DOT1S
Jan 30 16:16:53 sw1-2 BSP[unitMgrTask]: hpc_sfp_support.c(2818) 4647 %% Port 2/0/3: 10G DAC present, configured in CR mode successfully
Jan 30 16:16:53 sw1-2 DRIVER[unitMgrTask]: l7_usl_macsync.c(602) 4644 %% Couldn't install the mac address 10:xx:43:xx:4E:xx,vlan 400 on the unit with modid 0 and port 0 in the hardware
Thanks.
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    n__o_,
    Found out from the NETGEAR Support Team that you have an ongoing support ticket with them.
    Be informed that a new firmware has been released for the M4300 switch models which is v12.0.15.7.  If your M4300 switch is not yet in the latest version, I suggest you to update it.  Kindly read the new features & bug fixes as well as you can download it here.
    DaneA
    NETGEAR Community Team
    • n__o_'s avatar
      n__o_
      DaneA
      Thank you for your answer.
      I will update to the latest firmware and see what happens.
ProSupport for Business
