Orbi WiFi 7 RBE973
Reply
Switch Stack Questions
Breichert
Follower
I'm not very knowledgeable about switches and stacking since I don't work with them typically.  I have a few questions I'd like to ask.  If anyone has time to answer I'd really appreciate it.  Here they are:
  1. Is there a max length to the stack link between switches?  ie, we have a main server room plus a wire closet in a different part of the building.  Can I just have a couple of long ethernet cable run between the rooms and them all in the same stack?  Is this even a recommended practice?
  2. In a different building we have two separate stacks that are uplinked with just a gigabit ethernet line.  Is there a better way to uplink these two stacks?
  3. I have a stack 3 switch stack that is linked 1 > 2 > 3 but doesn't have a connection between 3 > 1.  Other stack I've seen have thing, is it necessary?  What does this link from the bottom of the stack back to the top do?
Thanks,
Brian
Model: S3300-52X (GS752TX)|ProSafe 48 ports stackable smart switches
Message 1 of 2
JohnC_V
NETGEAR Moderator
Re: Switch Stack Questions
Hi Breichert,
Welcome to our community! 🙂
 As long as the ethernet cable does support it, it will work. For an ethernet cable, max length is 295 feet(90 meters).
  1. In a different building we have two separate stacks that are uplinked with just a gigabit ethernet line.  Is there a better way to uplink these two stacks?
You can just create 1 stack on all your switches.
  1. I have a stack 3 switch stack that is linked 1 > 2 > 3 but doesn't have a connection between 3 > 1.  Other stack I've seen have thing, is it necessary?  What does this link from the bottom of the stack back to the top do?
You should have a connection going back to stack 1 for redundancy just in case 1 connection fails.
John
NETGEAR Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 697 views
  • 0 kudos
  • 2 in conversation
Announcements
