jamwil21
Sep 10, 2019Aspirant
Switch crashed hard and it will not load the new firmware
Greetings and good morning to all,
I need your assistance to this urgent matter. Our switch crashed extremely hard that it lost the previous firmware. So bad that I do not get the boot menu after you press and hold the Q key. I loaded Hyper Terminal and transfer the latest and greatest firmware using ymodem settings. Once it finished, it's asking various questions that I cannot find the answer on Google or other search engine; not even YouTube -> yes, surprisingly....
Any assistance on using the proper command syntax to mount volume and to load the iamge is greatly appreciated!!!
Status:
U-Boot 2012.10-00205-gef56c5f (Jan 01 2016 - 14:02:15)VerNo=1.0.0.7
UBIFS error (pid 0): ubifs_get_sb: cannot open "ubi:fs", error -19
UBIFS error (pid 0): ubifs_mount: Error reading superblock on volume 'ubi:fs' errno=-19!
ubifsmount - mount UBIFS volume
Usage:
ubifsmount <volume-name>
- mount 'volume-name' volume
UBIFS not mounted, use ubifs mount to mount volume first!
ubifsload - load file from an UBIFS filesystem
Usage:
ubifsload <addr> <filename> [bytes]
- load file 'filename' to address 'addr'
ERROR: can't get kernel image!
Saving Environment to SPI Flash...
done
Usage:
done
Usage:
ERROR: Ethernet external port not connected
at bcmiproc_eth.c:125/bcmiproc_eth_open()
m4300r2> ?
? - alias for 'help'
base - print or set address offset
bootm - boot application image from memory
bootp - boot image via network using BOOTP/TFTP protocol
bootz - boot Linux zImage image from memory
chpart - change active partition
cmp - memory compare
coninfo - print console devices and information
cp - memory copy
crc32 - checksum calculation
dhcp - boot image via network using DHCP/TFTP protocol
echo - echo args to console
env - environment handling commands
exit - exit script
false - do nothing, unsuccessfully
fsinfo - print information about filesystems
fsload - load binary file from a filesystem image
go - start application at address 'addr'
help - print command description/usage
i2c - I2C sub-system
iminfo - print header information for application image
itest - return true/false on integer compare
license - print GPL license text
loadb - load binary file over serial line (kermit mode)
loady - load binary file over serial line (ymodem mode)
loop - infinite loop on address range
ls - list files in a directory (default /)
md - memory display
mdc - memory display cyclic
mii - MII utility commands
mm - memory modify (auto-incrementing address)
mtdparts- define flash/nand partitions
mtest - simple RAM read/write test
mw - memory write (fill)
mwc - memory write cyclic
nand - NAND sub-system
nboot - boot from NAND device
nm - memory modify (constant address)
ping - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
reset - Perform RESET of the CPU
run - run commands in an environment variable
saveenv - save environment variables to persistent storage
setenv - set environment variables
sf - SPI flash sub-system
showvar - print local hushshell variables
sleep - delay execution for some time
source - run script from memory
test - minimal test like /bin/sh
tftpboot- boot image via network using TFTP protocol
true - do nothing, successfully
ubi - ubi commands
ubifsload- load file from an UBIFS filesystem
ubifsls - list files in a directory
ubifsmount- mount UBIFS volume
ubifsumount- unmount UBIFS volume
validate- Validate the image
version - print monitor, compiler and linker version
m4300r2>
- jamwil21Aspirant
Fireware : m4300v12.0.7.17.stk
- msiLuminary
Register your switch in My Netgear and open a case via Chat. This should work even after the 90d initial support as that's part of their lifetime warranty. You are stuck in u-boot and although there are likely ways for outsiders to guesstimate a way into getting either an image booted from the secondary partition I wouldn't lightheartedly mingle in U-Boot since you are still eligible to support.
If you get this fixed with their help, sharing your solution would be appreciated. Possibly they send you a new switch instead if it takes to long for them to fix this.
I could imagine that sending them outputs of the following commands including your error message might be helpful for a quicker diagnose:- printenv
- fsinfo
- ls
- version
printenv in U-Boot gives some information about boot arguments. There are different ways within U-Boot in order to boot or load an OS in another fashion that can but don't need to be specific to this switch. This is knowledge Netgear support hopefully should have since that is specific to their switch.
- jamwil21Aspirant
I'm still waiting on Netgear support personnel to contact me....
Please review the file attachment.
