RichWilson
Feb 07, 2019Tutor
Use of SFP to Router
What is the technical way to use two SFP ports on this switch to connect to a Nighthawk x6 router.
I have 2 Gbics, with 2 Cat7 RJ-45 cables. Is there other/additional hardware needed?
This would be the uplink from the swtich to the routher.
- JohnC_VNETGEAR Employee Retired
Hi RichWilson,
As per checking, the Nighthawk x6 router is already installed with 4 Gb LAN ports which is compatible with your M4100 switch. No need to install any additional hardware for it to work.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
X6 does translate to Netgear Nighthawk R8000 - this router model does not support the configuration of a port aggregation (LAG, trunk, ...) so taking an advantage of two links might becme difficult. JohnC_V
As per the year 2015 M4100 Datasheet the AGM734 isn't listed. Beyond, the AGM734 seems to be supported - as per AGM734 SFP Transceiver 1000BASE-T SFP COPPER RJ45 GBIC is suppoted just on two Netgear switch models. LaurentMa can you shed some light here please?
