Fannels
Jun 21, 2018Aspirant
VLAN's not talking to eachother
I have setup vlan 10 and 20 192.168.10.1 and 192.168.20.1 on my routing table,
Port G1 and G2 have both vlans on them but i cannot ping the pc in the vlan 20 range from the vlan 10 port
I can ping the gateways from the ports but not 20.1 from 10.1
what am i doing wrong?
- FannelsAspirant
I have a pc with ip 192.168.20.99 connected to port 2 (VLAN 20)
I have a pc with ip 192.168.10.99 connected to port 1 (VLAN 10)
I have set up PVID 10 on Port 1 and PVID 20 on port 2)
I can ping the VLAN 10 from port 1 But not VLAN 20 from port 1
I can ping VLAN 20 from port 2 but not VLAN 10 from port 2
I have settet up enable IP in routing and allocated 192.168.10.1 to VLAN 10 and 192.168.20.1 to VLAN 20 (i can ping these when im in the VLAN port but cannot ping both at the same time..)
The PCs involved are making use of the related switch LAN IP for the routing ie. each it's .1 for the default gateway?
- FannelsAspirant
Yes on the pc i had 192.168.10.99/24 with gateway 192.168.10.1 for VLAN 10
192.168.20.1/24 with GW 192.168.20.1
They still dont want to comunicate
i also followed these steps using routing wizzard and no coms.
https://drive.google.com/file/u/1/d/0B4PuVEYxkQ5oX0w0Yll0U1d2MlE/view?pli=1
