rovmi
May 24, 2016Follower
communicate between 2 VLAN's
I have a PROSAFEGS748T switch:
port 27 untagged vlan 30 pivd 30
port 41 tagged vlan 1 and tagged vlan 30 pivd 1
I have tryed different combinations of tagged and untagged.
a printer with 192.168.30.61 is connected to port 27
a PC with 192.168.30.10 is connected to port 41
I can't ping the printer.
VLAN 30 has more ports, whan I connect the PC to one of these ports I can ping the printer, so internal in a vlan everything works fine.
- DaneANETGEAR Employee Retired
Hi rovmi,
Welcome to the community! :)
You will need to configure VLAN routing on your GS748T switch. Let me share this article below as reference guide:
VLAN Routing on New NETGEAR Smart Switches
Hope it helps. :)
DaneA
NETGEAR Community Team
- JohnRoNETGEAR Employee Retired
Hello rovmi,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
