DelTorre's avatar
DelTorre
how I can find the IP of a device connected to the switch GS724Tv4 ?
I have a switch Netgear GS724Tv4 and I need to know the IP address of a device at the g19 port. Is possible through the switch to see it?
Thank you in advance.
Antonio
  • Hello DelTorre,
    Welcome to the community!
    Unfortunately, the GS724Tv4 does not have an IP address table. I don't see a way on how you can see it through the switch.
    Thanks,
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hello DelTorre,
    Thanks,
    • DelTorre's avatar
      DelTorre
      Thank you so much.
      I'll find another way :(
      Antonio
      • JohnRo's avatar
        JohnRo
        Hi DelTorre,
        You can probably get the IP of each device on your router's IP address table, but it will not tell you which port it's plugged into on the switch. I think arp commands will work.
        Thanks,
ProSupport for Business
