- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can't Enable Wifi on ATT M1100
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Guys
i Have bought two Att Nighthawk M1100-2A1NAS from ebay , one is working perfectly fine , but the other one only works thru ethernet or with USB C tether it always shows : Wifi Disabled
I tried to activate it in the router portal but it failed ,
I got a lot of issues in going into the portal it doesn't show up like you can see in attached files
I think this is a Software issue , someone has any clue?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can't Enable Wifi on ATT M1100
There's a hardware reset, did you try that?
Netgear Nighthawk LTE Mobile Hotspot Router (MR1100) - Reset Device - AT&T
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you checked to make sure IP-passthrough is disabled?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @DaCassilia06 ,
Can you please PM a screenshot of the device label? You will need to remove the battery to see the label.
Arodi
- Mark as New
- Bookmark
- Subscribe
- Permalink
I cant access to the portal , i think that he doesn't responds , for example when i want to reboot thru 192.168.1.1 it does absolutely nothing
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have your issue been resolved? If yes, can you share with us how? because I'm experiencing the same issue
