× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
M1 nighthawk boot loop
Q101
Follower
My Nighthawk MR1100 router constantly restarts. It initiates power on and the "NETGEAR" logo shows up on screen, the amber light shows up and then after 3-5 seconds it shuts off again and then powers back on to the same point. After 10 or so loops of this fashion the device reboot loop stops and doesn't power on again (to the loop) until I remove power. I have tried hard resetting it as well as removing sim, however the issue is unresolved.
The model version sku is MR1100-100NAS
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 2
Re: M1 nighthawk boot loop
Try this in the appropriate section of this community for the MR1100.
Mobile Routers, Hotspots & Modems
I will ask the Netgear moderator to move your message.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1334 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
